- Oct 5, 2007
- Reaction score
- 2,965
- Location
- Toledo Ohio
- Make / Model
- Fords
- Engine Size
- 3.0 2.3
I think that is per, T expensive
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
31 spline Explorer axle shaft lengths:31 spline Ranger shafts are shorter then explorer shafts (at least the '95+ disc brake explorer axles). I recommend ditching the FX4 axle and build an explorer 8.8... You can always find replacement shafts for those in the junkyard. If you want drums then the 1st gen explorer ('91-'94) 8.8 is the ticket and the rangers parking brake cables are plug and play. There is a slim possibly the drum brake explorer 8.8 axle shafts are the same length as the FX4. There is most definitely a difference in length of the axle shaft flange to axle tube end between 31 spline drum & disc axles.
