93 ranger 3/4 ton sas with leaf leaf springs and v8 swap
ranger302v8
302
So im finally starting my sas after blowing up my front end and tranny at the local trails.
Current vehicle specs:
1993 Ford Ranger Ext. Cab 4x4.
302 Fuel Injected v8
Automatic 4spd tranny
stock f-150 borg warner case.
6 inch skyjacker lift kit.
35x12.5x15 BFG mud-terrain km2's
Stock 15x8 ranger rims
Custom rear pipe bumper.
homemade 3in body lift
SAS plans:
3/4 ton axles out of a 1977 ford f-250 custom
front and rear axle and leaf spring swap
351 Modified carberated motor swap.
4 speed manual granny gear tranny.
205 t-case
38" Swamper's or Baja Claws
20" Moto Metals
Questions, Comments, Tips are welcome. No bashing im 19 working on a tight budget.
this is how i bought the truck before the body lift.
77' F-250 3/4 ton. Picked it up for $1000 built 351 winsor.
Front axle on ranger pulled.
Rear axle on ranger pulled.
F-250 cut in half.
Rear axle out of f-250
Thats all i got so far gonna clean up and paint the f-250 axles this week. Keep pics updated as i go.
jhammel85
Guest
Not bad at all! I'm digging the F250, too bad it's being chopped for parts.
Either way, truck will be even better with what you are putting in. Are you freshening up that 351W?
ranger302v8
302
well if the f-250 body wasnt so rusted up i would tag it and drive it everyday i love that truck. as for the 351 im gonna clean it up and paint it and put a few new parts in it here and there it runs like a dream already no ticks or knocks.
White94Ranger
Aldergrove B.C
2.3
sweet build man, would you happen to have any build pics of that efi 302 build? awesome truck so far.
ranger302v8
302
sorry i dont i have pictures of the motor in the truck already. some advice if you plan on doin the 302 swap put on a body lift it makes so much more clearence for the motor.
ranger302v8
302
Update: Got the front end tranny and transfer case out of the 250 today.
took alot of hammering and prying to get the leaf springs undone and two broken steering bolts but it'll be worth it in the end
ranger302v8
302
here's all the pics i have right now.
302 EFI in the Ranger
351 Modified in the F-250
ranger rear end
before the project how i bought it
stuck before the swap when the 4wd was broken
again
'84 Bronco II
Cool build!:icon_thumby:
A few questions though, why run Ground Hawgs? Tire technology has come a long way in thirty years:D Also, do they even make 'Hawgs for 20" rims?:icon_confused:
Also, why not run a radius arm set-up in the front? I know leaf springs are stupid simple, but your ranger is already set up for radius arms and coils which will take some work out. Also, front leaf spring bring the suck when it comes to an approach angle. The only real difficulties I see with keeping radius arms and coils are fabricating a track bar and welding some radius arm mounts on the axle. Of course it looks like you like to run in the mud, so maybe leaf springs won't be as much of a hindrance for you.
Either way, have fun with your build, it looks like you are off to a good start:icon_thumby:
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
I like everything about this build except for one thing.......FOR THE LOVE OF GOD DON'T GET 20'S!!!!!!!!!!!!!!!!!!!!!!!!
ranger302v8
302
im getting 20's or something close to it because i hate big tires on small rims. Cant stand the look.
And im doing leaf springs because i use the truck more for mud and a dd i live in florida not much climbing to do around here.
ChrisR1S
10/2013 STOTM Winner
MTOTM Winner
Southern Virginia
Mild 5.0
Lookin' good man! what leaves are you going to run in the rear? And I agree, no 20s! I'm running 18s on my 37s and IMO they look perfect proportionally
mhughes165
9
302
if u are SAS'ing the truck and plan on some serious wheeling i would seriously suggest go NO BIGGER then MAYBE a 17 or 18, unless u have a good amount of stock in ur wheel company and dont mind replacing TRASHED 20s all the time..
and denman has never made a groundhawg for a 20" rim
ranger302v8
302
im runnin either the stock ranger springs or the stock f-250 springs.
and as for the tires im gonna be runnin what ever i can afford in the beginning.
Boggin
48
cool build but personaly i would say fuk the ranger and id rock the f250 but thats just me
ranger302v8
302
Well like i said before the f-250 is rusted out has holes all over the cab and cracks all through the windsheild so it wouldnt be worth the money to tag it.
