94 4.0l ohv severe oil leak
black_demon69
142
AZ
4.0l
ok here is what has been done
complete engine rebuild so all gaskets are all new
got it back in truck and running was checking for leaks etc. and found a severe oil leak located at the rear of the oil pan on the right side..
pulled trans because i suspected faulty rear main seal seal was dry but there was some oil between oil pan and block so engine was raised and oil pan was pulled and oil pan gasket was replaced.
put truck all back together just to find that it is still leaking in the same place.. could this just be a cracked oil pan? or just the stupid after market design of the oil pan gasket which varies from the OE style in groove gasket?
also does anyone know where to find the OE style Gasket?
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
It's very possible the pan is just warped. Also did you use silicone in the corner joints?
black_demon69
142
AZ
4.0l
yes and on second attempt a thin coating of silcone all the way around on both sides of gasket... just for good measure LOL!!!!!
so you suggest a new pan ?
black_demon69
142
AZ
4.0l
and everything was very clean and bare metal
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Well I would put the pan on a flat surface and inspect the sealing flange. If its obviously warped then yes replace it. Did you also make sure the leak isnt originating from somewhere higher up like the pressure switch, even the back of a valve cover can leak down and look like it's coming from lower on the engine.
black_demon69
142
AZ
4.0l
Yes I did it is definitely coming from just below the rear main seal
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Without looking at it my personal opinion would be its leaking from the corner joint then. It's really easy to squish those joints or not seal them properly. The one peice gaskets solve that issue but as you've found... not easy to find sometimes.
I would check the pan for warpage, if its good, install the gaskets with high tack on the pan. Let it dry. Then add the RTV on the joints, install the pan hand tighten the bolts only! Wait an hour, then torque them down in a cross pattern keeping a close eye that a corner doesn't squeeze out.
black_demon69
142
AZ
4.0l
Gasket won't squish above is the style of the gasket but one on the truck is Fel-pro
The OEM GASKET IS IN Chanel gasket so styles are different
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
So they are both one peice? Not 4? I'm not a 4.0 expert. But have changed many oil pan gaskets lol.
If the one you have is still one peice then I'd be inclined to blame the pan.
It is leaking because you have the wrong gasket.
You need a Fel-Pro OS30634R
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Ya'll know my advice.
black_demon69
142
AZ
4.0l
It
is 1 piece but it seals just right on the very thin inner edge right next to the original channel that the OEM GASKET sat in.
black_demon69
142
AZ
4.0l
Pan didn't leak prior to the rebuild and was not dropped or anything so I think it is cracked up towards the top on that side.
