dana 44 bolt pattern
fordguy64
cinci,ohio
do any dana 44's come with a 5x4.5 ? i dont think they do but i just thought i would ask...
Thanks
Rob
JohnnyU
"Outlaw"
8
Chillicothe, Illinois
Chevrolet
Ls2
Yea, but they were junk.
The current Wrangler Rubicon comes with a "44" and has 5x4.5" lug pattern, but thats kind of different....
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
'75-'79 Dodge half-tons (5x4.5").
The cartridge wheelbearings ain't the greatest though, and there are no locking hubs on it (plus, the diff is on the wrong side, you'd have to swap the outers onto something else (or re-tube it). Not worth it).
fordguy64
cinci,ohio
ok thanks guys... anyone know a good place to get the axle shafts shortened? i can shorten tubes myself....
fordguy64
cinci,ohio
any others come with the 5x4.5 pattern?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Nothing that isn't weaker than what you already have now.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
It would be easier and stronger to just get wheel adapters for the rear axke and go to 5x5.5
fordguy64
cinci,ohio
yea well i really want to keep the truck narrow.... and i just bought new wheels and tires for it like 5 months ago.... so gonna try everything i can to keep it 5x4.5 altho im starting to realize that thats probably not going to happen...
Legion
Austin
hitech_hick
Madtown, USA
Axles aren't the only thing that makes a truck wide or narrow, rims play a bigger part. My stock axles with 10 inch rims with 3 5/8th's inch back spacing are as wide as a full width axle with stock rims. The only difference is that my truck eats wheel bearings and ball joints where as it wouldn't with full width axles.
hick
rickcdewitt
5
nor-cal
4-0 swap
you might look for a wrangler 44 they will handle 37's or so.a little wider though and no lock outs.stronger than ttb but not the strongest 44
fordguy64
cinci,ohio
ok so does a dana 44 that has a pass side drop spin the same way as a driver side drop? like if i buy a scout axle thats pass drop and re tube it so its a driver side drop will it still spin the right way?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Retubing it will work, yes (the centersection is built the same, although could have a leafspring mount cast in the opposite side, or other similar variations).
The Wrangler (Rubicon) D44 uses D30 outer parts. It wouldn't fare much (if any) better than the D35 would (but would still be better than the small-ring-geared D30). I'd run 35s max on it under a Ranger.
fordguy64
cinci,ohio
so i found a guy thats selling scout axles dana 44 f/r are scout dana's any good? im assuming that all dana 44's are fairly equal i know there are like 1/2 ton and 1 tons...
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
IIRC, Scout axles had VERY long steering arms on the knuckles, you won't get your full turning radius with those.
