End Play At Rear Wheels
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
There should be no need for a recess if the clip is the correct thickness (that would defeat their purpose anyway). I recall they were specifically for the purpose of minimizing the axle end play (each clip was different by maybe 3-5 thousandths or so).
:dunno:
8thTon
--- Banned ---
806
Pennsylvania
Given the factory spec appears to be 0.030" max, 0.003-0.005" wouldn't do a whole lot?
Junk Collector
Truck of Month
4,836
Rapid City SD
I'm just wondering now if I'll end up replacing the side gears and curved washers behind them instead of the c clips. I don't see how a c clip by itself could ever take up 1/4" of slop. Something else has to be worn too.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
If there's 1/4" of play, there definitely is another issue, especially if this is on an open diff.
Sounds like time for a teardown. If parts are damaged/excessively worn, I'd say now's a good time to swap for that 8.8".
