I originally liked driving them, down hills they hold back like a standard. Some people really had trouble getting used to the way they work, if you touch the brake at all the clutch disengages, once you apply throttle it slowly engages the clutch and you drive away. There is no holding a car in place on a hill by applying a little gas, it engages and drives away. The biggest thing I didn't like was trying to back on in between 2 other new cars in a snow covered lot, without being able to modulate the speed with the brake it was tough to keep from side swiping another car. I was able to cure some chattering clutches by accelerating WOT up the highway ramps and making it shift through the gears a few times.Overly gentle drivers cause the clutches to slip, get glazed, and chatter. Heavy footed drivers had fewer complaints.Another item: Fiesta 1.6's have timing belts and Focus 2.0s are chain drive. Both are interference engines- meaning if the belt brakes the valve will hit the pistons. It's dumb but that's what happens when the Europeans "help" us.
