Help
Josh B
1,988
Oklahoma
I'm not certain your mechanical knowledge or ability but a good inspection would tell a trained mechanic what he needs to know about what's going on in there, and its cause
You'd have to pull the intakes, and onward to the heads until you found the source
johnv
6
Loveland,co
Ford ranger stx
Got recommended a shop by the tow truck driver and well says I need a new motor. Head gasket went and coolant in oil and bunch of other stuff $2000 in just labor cost to fix. And asked another shop how much for rebuild/ reman engine and install and they said $7500. So think I'm gonna sit on it for a while and save up to switch it out to a 4.0l sohc engine.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,871
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
You would be better off going with a 4.0 OHV engine. More compatible with what you have than the SOHC.
johnv
6
Loveland,co
Ford ranger stx
Oh okay. And my buddy made a fair point he said did the shop guy say why I needed a new motor or what not. And all the shop guy said was head gasket blew and coolant in the oil.
sgtsandman
Ham Radio Operator
12,871
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Swapping an engine is easier than repairing one. The shop either doesn’t want to do the work or there is more profit in it for them doing a swap rather than a repair. Plus, it will take more time to repair than swap. Time is money and a lot of times getting a vehicle done faster so the next one can come in makes more money than working on a more extensive project on just one vehicle.
johnv
6
Loveland,co
Ford ranger stx
Oh makes sense. Well gonna probably get it towed to my house and have it sit in my garage for a bit. Where would I find a 4.0 ohv engine and compatible transmission?
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
Depending how long this was going on the bottom end might be fine...
johnv
6
Loveland,co
Ford ranger stx
What do you mean?
Blmpkn
Toilet enthusiast
6,438
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
What do you mean?
He means that if it was caught soon enough, the coolant in the oil isn't to the percentage yet where it's going to ruin your bearings.. and you can just get away with headgaskets & whatever else instead of replacing the entire thing.
johnv
6
Loveland,co
Ford ranger stx
Well it only recently got milky. So should I get it sent to another shop to be checked?
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
Heres what i would do...
Drain the oil out of it
Replace the headgaskets/heads (if they are cracked)
Refill with fresh oil/filter
Drive 3 or 400 miles
Change oil again
Drive 1000-1500 miles
Change oil again.
Then resume your normal oil change schedule.
A shop cant tell you without a teardown how much damage has been done to the rods/mains.
sgtsandman
Ham Radio Operator
12,871
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
If you are going to let it sit, drain the oil and put fresh oil in it so the coolant contaminating the old oil doesn’t make the internals rusty and make things worse.
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
Actually maybe drain the antifreeze, dump in fresh oil, let it run 2 or 3 minutes then leave it sit.
johnv
6
Loveland,co
Ford ranger stx
Kinda leery of letting it run tho with the new noise it made the last time I ran it.
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
