is this normal..
8,372
OD is Overdrive, Overdrive is 5th gear in a 5R transmission, solenoid 3(C)
OD off simply means computer will not activate Overdrive when you are going fast enough to need to shift to 5th gear, transmission will stay in 4th gear, until driver turns OD on again
OD off doesn't effect 1st, 2nd, 3rd or 4th, just whether 5th gear is used
Shifting stays the same from 1st to 4th
I am glad OD off works for your situation, but on paper it should have no effect :)
wpginterceptor
Law Enforcement
9
Winnipeg
even when truck is well warmed up, i played with the OD and it def has diff shift points from a dead stop to 50 mph as compared to overdrive off.. For 1 example, im crusing at 38 mph and truck is doin 2200 rpm, I turn OD on. and it immediatly drops to 1800 rpm (dont feel it shift gears)
pjtoledo
2,997
Toledo Ohio
Fords
3.0 2.3
OD locks the torque converter in 1 thru 4., the owners manual details how it can be used for engine braking while towing.
the 2200 to 1800 drop is the converter locking up.
wpginterceptor
Law Enforcement
9
Winnipeg
yeah unfortunitly i dont have an owners manual for this truck.. just that first drive when cold out issue of hard shift for first couple mins! im startin to think its normal. BUT i know my 2002 ranger didnt do it. only diff was my 02 had 3:73 and my 06 has 4:11
don4331
1,353
Calgary, AB
5.3
How a 5R55E shifts:
1st - low speed planetary 2.47:1 ratio
2nd - low speed planetary 2.47:1 ratio + overdrive planetary 0.75:1 = 1.87:1 ratio
3rd - medium speed planetary 1.47:1 ratio
4th - straight through 1:1 ratio
5th - straight through 1:1 ratio + overdrive planetary 0.75:1 = 0.75:1 ratio
Turning off OD aka 5th is recommended for towing as Ranger often is short of power and constant shifting from 4th to 5th really heats things up. Hot transmissions don't last...
I know the 5R110W found in SuperDuty Diesels becomes a 6 speed when cold out. Otherwise, it is a 5 speed with same shift pattern as the Ranger automatic.
It adds the medium planetary + PD planetary ratio (which would be about 1.10:1) when cold​
I'm wondering if turning off OD, actually "removes" 2nd from shift pattern too. A shift from 1st to 3rd with lots of slip would be a gentle shift.
Then there is what is happening with the torque converter lock-up - which is also modified by thumbing the button
wpginterceptor
Law Enforcement
9
Winnipeg
UPDATE: ok so 2-3 weeks ago i was complaining about high rev's from first drive goin down my street.. This morning I left and same issue.. shifted well over 3000 rpm 1-2nd gear shift, a hair below the first mark 3250 rpm it shifted and then my OD LIGHT began flashing.. Looks like Im gonna change the Speed Sensor ! The light went away after I got to my destination and restarted the truck.. but ill change sensor and see if it clears up! the truck did drive normally again as usual about a block and a half away from home but light continued to flash. i drove for about 15 mins to my destination and shut off, then restarted for drive home and no flash and shifted normal.
8,372
Over 3,000rpm would have been a shift from 1st to 3rd in a 5R transmission usually
2nd would be a 600rpm drop, 3rd a 1,100rpm drop
So if RPMs were 3,200 and dropped to 2,100 then it skipped 2nd and went to 3rd
If RPMs only dropped to 2,600 then it was a shift to 2nd
Flashing OD light means transmission codes were set
In 2006 speed sensor is the OSS(output shaft speed) sensor on the upper rear of transmission housing, its2 wires run directly to PCM(computer)
PCM converts that signal and sends it out to the speedo/odo, and cruise
So speedometer would for sure have issues if OSS sensor had an issue
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
My 4.0 OHV shifts a little harder at first when it's cold out. Maybe you should do a tranny flush. Your T fluid could use a change/service perhaps.
wpginterceptor
Law Enforcement
9
Winnipeg
it might of been 3000+ from 2nd gear to 3rd... either way the light immediatly began flashing! Ive read of this and heard replacing the speed sensor cures this. Ill try it. I believe its on top of the rear diff on my 06 as its a 2WD.
"""My 4.0 OHV shifts a little harder at first when it's cold out. Maybe you should do a tranny flush. Your T fluid could use a change/service perhaps. """ i had the fluid changed about 20 000 miles ago but not the filter..
flashin OD light.. Ive seen this video and others with same issue as me.. NO SPEEDO ISSUE EITHER....... Flashing OD Light & Hard Shift on automatic Ford. Replace Transmission or install $20 Speed Sensor? (youtube.com)
8,372
Only the 1998-2000 Rangers used the rear axle ABS sensor as a "speed sensor"
Read the link you posted above
"Flashing OD Light & Hard Shift on 1998 Ford Ranger automatic....."
A bit lower he says "Replacing speed sensor also worked on 2006 Ford Ranger...." this would not be the rear axle sensor, for sure
So not applicable for/to 1983-1997 or 2001-2011 Rangers
Flashing OD light means computer has detected a problem in the transmission, so will set a transmission code or codes
Not all code readers can see these code
Auto parts stores will often read codes for free, WRITE them down, need EXACT code numbers
And there are A LOT of transmission codes
Partial list here: https://www.therangerstation.com/tech/obd-ii_trouble_codes/
They start at P0700 to P0804
And then again at P1700
So guessing is out of the question, lol
wpginterceptor
Law Enforcement
9
Winnipeg
yeah my truck not showing check engine light and the OD light isnt flashing anymore, and my reader not showing any codes.. So the Speed Sensor is located on the trans.. ill change that first and see
so ill make sure its not the one for the ABS wheel sensor but the Output speed sensor on the diff.
8,372
On a 2001 and up Ranger if speedometer is working then a speed sensor is not the issue
What is the model number of the OBD2 reader
Look it up and it should say if it can read transmission codes specifically, most can't
wpginterceptor
Law Enforcement
9
Winnipeg
I have 2 readers and both nothing.. there is no check engine light and OD light isnt flashing anymore.
well after reading many similar issues on other forums etc seems like I have same as these other owners do and they changed the Speed Sensor and it fixed the issue.. for 20$ ill try it. and they said there speedo was working also.
wpginterceptor
Law Enforcement
9
Winnipeg
OK so updating this video...
After talking to a Ford tech who knows my trans best, he says its NORMAL for the OD light to flash if its cold out and I didnt allow the truck enough time to warm up. He says The next time you shut it off and start it up the light will stop flashing and be back to normal..
Yeah thats exactly what happens... Strange my old 2002 Ranger NEVER did this... my 06 has done it twice this winter! Next fall i plan on using synthetic trans fluid and well see what happens next winter. In the end he says this is normal and to only worry about it if the light continues to flash after a restart, OR the lights flashing and its not cold out!.. if that happens, he recommends changing the speed sensor and if that doesnt stop it then to have a pro look at it as it will be a bigger issue......
sgtsandman
Aircraft Fuel Tank Diver
12,753
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Just as an FYI, actual Motorcraft Mercon V is a synthetic transmission fluid. Also, when was the last time the fluid and filter was changed? It might help some if those haven't been changed in a while. Some people use 60,000 mile fluid and filter change intervals, others use 30,000. I prefer 30,000 but I wouldn't go more than 60,000 miles.
