Frank de la garza
- Apr 6, 2023
- Reaction score
- 4
- Location
- Texas
- Make / Model
- Ford ranger
- Automatic
Replaced rear main seal and still leaking
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
AutomaticAuto or manual?
Sometimes front seal leaks on an auto can be mistaken for rear main on the motor.
Other then that it could be the oil pan. VC gaskets generally leak all over the exhaust and cause a smokey condition and a stench
It’s clean thief .Another place that can leak oil that can end up under the rear mail is the o-rings in the oil filter adapter.
Down the front of the flywheel(toward engine) or the back(toward trans)?I also replaced the valve cover gaskets. Between the engine and transmission there is cover with two bolts holding it in place and You can remove one bolt and you can move it over and you see the fly wheel. Their where I can see the oil dripping out.
