Rear main seal
tinman_72
139
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
The next culprits would be intake or valve covers.
rusty ol ranger
2.9 Mafia-Don
7,696
Michigan
177 CID
Auto or manual?
Sometimes front seal leaks on an auto can be mistaken for rear main on the motor.
Other then that it could be the oil pan. VC gaskets generally leak all over the exhaust and cause a smokey condition and a stench
Junk Collector
Truck of Month
4,861
Rapid City SD
Distributor has an O-ring on it that is a common leak spot on 2.9s as well.
RobbieD
2.9l Mafia
3,572
Georgia
Another place that can leak oil that can end up under the rear mail is the o-rings in the oil filter adapter.
Frank de la garza
4
Texas
Ford ranger
Auto or manual?
Frank de la garza
4
Texas
Ford ranger
I also replaced the valve cover gaskets. Between the engine and transmission there is cover with two bolts holding it in place and You can remove one bolt and you can move it over and you see the fly wheel. Their where I can see the oil dripping out.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
was it grooved? may need a repair sleeve. assuming the pvc is working correctly
Frank de la garza
4
Texas
Ford ranger
Man, shop replaced it, no way to know.
Frank de la garza
4
Texas
Ford ranger
You know what, I will change PCv valve, thanks
mikkelstuff
469
Brighton, CO
3.0L
Don't know about the 2.9L. If a 3.0L, it would be the oil pan gasket.
Frank de la garza
4
Texas
Ford ranger
forgot, also had the oil pan gasket done.
rusty ol ranger
2.9 Mafia-Don
7,696
Michigan
177 CID
Down the front of the flywheel(toward engine) or the back(toward trans)?
Frank de la garza
4
Texas
Ford ranger
Front of flywheel and engine
