Tuning options for a 3.0
33
Virginia
3 Front, 5 Back
After experiencing the surprisingly low fuel economy on my 3.0 ranger, I have been looking into blocking off the EGR and deleting the secondary cats. I daily drive this truck and want to keep my engine happy with a tune.
My truck is ECC-V and from the research I have done, TunerPro can make files compatible with this ECU. However, I have no idea how to actually interface with the ECU. Is there anything out there that will just plug into the OBDII port so that I can use my laptop for tuning? I am not too concerned with the software side of things, I’m a CompSci student so I’ll figure that part out.
ericbphoto
Overlander in development
16,712
Wellford, SC
6"
What about using the same adapter used for Forscan? I dontrecall the specs or model # at the moment. But Forscan gets you into the Ford ecus
33
Virginia
3 Front, 5 Back
Will this let me flash the ecu? Also has anyone on the forum here self-tuned their trucks?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Tune the engine with normal forscan?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
HP tuners tuner pro? Just plug your hpt in.
ericbphoto
16,712
Wellford, SC
6"
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
That's what I was thinking. Isn't that one of it's main functions?
Not forscan. It does modules. There is a version that can write, but it is not forscan...doesn't comm with the modules just the ecm.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Tuner pro and core are similar... the oem guys leave back doors for a reason.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Wouldn't an egr delete cause worse mileage? I know it did/does on gm 3.8s..
The 3.0.. all the power of a 4 cyl with the efficiency of a 4.0 lol. Just how bad is your mileage anyways?
Gonna be difficult to increase efficiency a meaningful amount. The drag coefficient of a Ranger is literally closer to a peterbuilt than it is a Honda civic.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Egr delete can cause worse mpg
Egr delete properly tuned will only increase mpg and engine life.
franklin2
1,769
Virginia
I agree if you are stuck with the stock tune. If you tune it without the EGR, you will have better power and throttle response and less throttle opening required to maintain the same speed.
EGR is a emissions thing, nothing to do with increasing fuel mileage. I think it is better to say to just disconnect it and do nothing else, may make the engine run worse.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
yes....timing is changed and fueling for certain conditions.
the fuel mileage increase is merely potential with tune...but generally attainaable.. but, it is a given over time because of the lack of shit loaded up in the intake track....from sucking combustion ...
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
650
Central Indiana
There are way better ways to improve fuel economy than deleting emissions hardware/software.
