Wow I wish I had some of what u are smokin...not to be a dick but u obviously hsve never got an oil analycis done b4...now way in hell u can go longer then 3k miles on an oil change unleSs u are using that new NASA approved shit. When an oil turns black is because of heat breakdown and carbon. Keyword breakdown. Meaning lubricicity gets lower, which is the whole purpose of oil. Stop and go and long idleing kills oil because of the quick heating up and coolong down breaking down the oil, hence thermal breakdown. Yea u could run 75_90 for 9k miles and itd proLly be as thin as 5-20. But seriously its not just the oil that's the reason to change evry 3k. Your filter can't filter but so much b4 it starts making yer oil pressure go down. Which in turn starves bearings and other critical componants of oil, which in turn raises the oil temp increasing the possibility of "baking" on sludge and gunk. Think about it. Also run your oil for 5-7k and cut open your filter, then do the same for 3k and u might have second thoughts. Sorry for the shitty typing I'm on my phone
Wow, not to be dick also, but you obviously know nothing about oil. First of all the color of an oil means NOTHING!!!! You ever see oil ran in a diesel after only 500 miles? Black as a midnight sky. Does that mean it’s bad? Hell no! The black color is NOT from breakdown, it’s all the dirt and crap that’s being held in suspension. In other words, it’s the dirt that’s NOT staying inside your engine. Think of it like a mop and bucket of water. As you clean, the dirt that WAS on the floor is now in the water. After a while, the water turns dark. Oil of course will eventually get dirty enough that it needs changed, but 3k miles is way too soon.
Obviously YOU have never gotten a UOA done because if you did it would’ve shown you could’ve gone much longer than 3k. Go to bobistheoilguy.com and you can see LITERALLY HUNDREDS of UOAs that show 5-7k is perfectly reasonable. Not to mention tons of internal engine pics on engines that ran 5-7k intervals their whole lives and not a speck of sludge.
Your analogy to 75w-90 gear oil also shows how much you don’t know. 90 weight gear oil is about the same viscosity as 10w-30 motor oil. They just use a different rating scale for gear oils.
And I HAVE cut open filters after 5k. You know what I found? Not a speck of grime in it!
Guys, this isn’t the 1970s anymore. Back then, you HAD to change every 3k. But oils are literally hundreds of times better now than they were back then. The oil companies are CONSTANTLY reformulating their oils and improving them. The new ILSAC GF-5 spec just came out last month. (If you don’t know what that is, don’t even TRY arguing with me about oil…)
Going back to my 1970s analogy…back in the 1950s you had to change oil every 1k miles, once again because oils were so crappy back then. But over time, oil technology improved and 3k became the new standard. And I’m sure all the old school guys thought 3k was crazy and said “no way can you go longer than 1k miles!!!” (SOUND FAMILIAR??)
…once again, oil technology has improved and 5k is the new standard. Get with the times people
