Door lock cylinder retainer clips - what's going on?
DoctorRoboto
Portland, OR
When life gives you lemons, just shut up and eat your lemons.
I've got the door panel open on my 1995 Mazda B3000, because the outside door lock doesn't work. I found that the plastic clip that translates motion from the lock cylinder to the rod (which is completely missing) is broken, as seen in the picture. But I can't find a replacement for this thing, I don't think. The only ones I see have a circle cut in the hub, like the second picture.
Do they still make the clips like what I actually have? Will these other clips work? And what is the connecting rod called, so I can find it to purchase somewhere?
DoctorRoboto
Portland, OR
Okay, since nobody answered this, I figured it out. None of those parts are right. I took the door lock cylinder to a locksmith, and they had a few Ford tail stock pieces. I then went to the hardware store and bought some aluminum rod. I haven't bent it into shape yet, but I'm going to make a replacement lock rod since there wasn't one in there.
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
Me, I'd go to a yard and get the needed pieces (they are all the same for years and years). I replaced all that stuff from a yard after getting the door punched. Think they charged me 5 bucks.
It is a lot easier to get it reassembled with the rod already in place in the cylinder.
